1 - 7 of 7 Posts
KK imma n00b when it comes to folding with that said , Im having troubles setting up the HFM.NET proggy I tried to follow the easy to use guide and for the life of me I cant find the folder for the log so..I made a new folder in the
program files in HFM.net proggy and directed it to the location I dont know if thats the correct way? with that done I pull up the app HFM and it shows offline? am i doing something wrong? the [email protected] program shows im working. Im running the system in my sig.
on another note it shows only 30% of my cpu is being used I set it to 100%
and set the check mark to slightly higher is this correct? or is it based off my GPU?
Did you download the right program? Sounds like you got the Unicore client instead...
Direct HFM to C> Users> [Your User]> AppData> Roaming> [email protected] and see if there's a log there. If there is, then you've got the wrong client, which explains the 20% usage and HFM not working.
I DL the Windows SMP Client and HFM.NET. Under "Featured Downloads".
(Direct Link) I havent a clue if those are correct ...by golly I thunk i done it , even a blind hog gets a nut once in awhile ...all seems to be working ..thanks a bunch for your help, on another note do I need to join a GPU team of sorts?
Good to hear.
You can check here for info on teams and the GPU team competition, but you can also just fold for OCN.
Yes you can, but for the GPU/Original contest, you can only have one of each folding under a single username (meaning you can't fold on both for the same username and take part in the GPU contest).
However, for the Foldathon (and upcoming Chimp Challenge) and non-contest folding, you can fold on as many CPUs/GPUs as you want.
1 - 7 of 7 Posts
