A day late, but my HFM didnt catch it till now so figured i would post it.
First thing i noticed is a fix for fermi client type, it now says GPU!
Auto size grid! Woot nice feature, i switch from my 19" to 40" alot...
HFM update
Source
Direct Download
Release Date: June 27, 2010
Enhancements
Enhancement: Issue 76 - ETA as a Date or as a TimeSpan: Added Preferences option to display the unformatted value as a Date rather than the default TimeSpan.
Enhancement: Issue 79 - Added options for HTML and/or XML web gen upload. You can only deselect HTML if XML is specified. If XML is deselected and HTML is not already selected, HTML will be default to selected.
Enhancement: Issue 155 - Add capability to specify the maximum size of the FAHlog.txt files being uploaded via FTP.
Enhancement: Issue 193 - Add Client Version to Client Type Column and Combine Core and Core Version Columns: Added Toggle option (View Menu / F11) to turn this data on/off. Also replaced the Core Version column with Core ID (hex core code).
Enhancement: Issue 206 - Display Timezone on Generated Web Pages (after time).
Enhancement: Issue 76 /193 - Update XML and XSLT files used for Web Generation to comply with primary grid updates (non-breaking changes - custom XSLT should continue to work fine).
Enhancement: Recognize OPENMMGPU core WUs as GPU Client Type.
Enhancement: Add Verbose Debug code showing PPD calculation values.
Enhancement: Add 'Auto Size Grid Columns' item to the View Menu. Column Auto Size now leaves the column slightly wider than before - to give each column's text a little more "buffer" room.
Enhancement: HFM.Plugins.dll - This will be the project that will specify the third-party consumable interfaces allowing input/output plugins to be created.
Changes
Change: Folding Instance Setup and Preferences dialog backends have been mostly rewritten.
Change: Increased the relative width of the standard "Overview" web page to 32% - allow room for the new UTC offset value without word wrap.
Change: If an Add or Edit Folding Instance operation fails due to a duplicate name, show the dialog again with the same settings that had already been input... gives the user a chance to correct the duplicate without having to enter ALL the data again.
Fixes
Fix: Issue 210 - Remove smb:// as a valid URI protocol for an Http Instance.
Fix: Issue 211 - Built on date with wrong locale on About Dialog. Forcing to Invariant (en-US) culture until application is localized.
Fix: Turn off LogViewer Word Wrap. If Word Wrap happens it screws up the line coloring.
Fix: Update custom grid painting code to fix some drawing abnormalities under Mono - looks much better now.
HFM update
Source
Direct Download
Enhancements
Changes
Fixes
