1 - 1 of 1 Posts
i have 6 slot for PCi-e and 3of them are used with 580's in Sli and i have a ethernet controler and a soundcard when i plug everything the second slot just doesnt work so my sound card doesnt work and if i try to just put one card in that second slot it works i did that too see if the motherboard slot wasnt the fault but seems like its not the problem
my 4th slot is empty i have nothing on it the rest is used ! so i dont know what to do my onboard ethernet is dead and i cant use the 6-pin near the Pci-e slot cuz my PSU wire are all used a XFX1250watts
please helps !
1 - 1 of 1 Posts
