1 - 17 of 17 Posts
Hello everyone, looking to find a good PC-centric community, google has brought me here plenty of times, for my questions and such, so I figure why not join.
My current PC is an AMD A8-3870k based machine, I originally planned to add in a 6670 for Hybrid Crossfire, but I found a 6950 on eBay for $125 so I'm now running that, unlocked shaders and overclocked. Eight gigs of RAM at 1866, Hyper 212 Plus CPU cooler, my APU is OC'd to about 3.4GHZ. Looking to get another 69xx card for Crossfire, but I'm sure my APU will be bottlenecking the cards.
Also I'm into music, I play drums and guitar (and I guess bass by default), been a Nintendo fan for probably fifteen years now, and I enjoy learning anything I can.
r/madlads
I'm pretty sure you can push the APU way further than that with the Hyper 212+
But anyway
I'm also into music and thrash metal and metalcore is my 2 highest ranked loved genres
I only added the cooler a few weeks ago, haven't pushed it much. Ran it at 34 x 100 and got a blue screen, so I'm now at 31 x 110 at stock voltages. Any tips? My only OC'ing experience is with this APU, mostly on the stock cooler so I didn't do much.
Leader of the #1 [email protected] Team
You might have to lower something on the CPU or RAM, or up the Vcore some. Not a big fan of APU's, the Buit in GPU i have been told doesn't make OCing as easy as a PII or FX.
Discussion Starter · #6 ·
Yeah, I was originally aiming at a budget gaming system, but now I just want more power. Sort of biased towards AMD, I like underdogs, and my case is the Thermaltake V3 AMD edition, so I'm limiting my CPU upgrade to AMD. Been looking at the FX-6300, which obviously entails buying a new motherboard as well.
Its a small letter L. Btw enjoy your stay
If you gonna go AMD, get a FX-6300 and OC to 4.5Ghz+ I would say get a FX-8350, but their only 4 cores with 8 Threads, so a 6300 vs a 6 "core" 8350, the 6300 would win.
Here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
$280 Total not including S/H and your on the Edge of PC Performance again
Pair that with a HD 7970 OC/ 6950 CF and your set
Here:
I'm kinda set on the 69xx Crossfire, I got the 6950 for only $125, so unless I can sell it for a nice profit, adding another would be the most cost-effective solution for me I think.
r/madlads
Are you kidding me? By your logic the 6300 would be a 3-core with HT
It just isn't.
It just isn't.
Face-Palm.... The 8350 is a 4 core 8 thread CPU, the 6300 however is a 6 core 6 thread CPU. Look it up sir
r/madlads
Look up, where?
You've got to be kidding me son. 8350 is a 4 module 8 thread CPU not a damn 4 core CPU and the 6300 a 3 module with 1 module laser'd off
That kind of logic of yours makes me feel like i'm on a Intel thread with the 8350 coming from intel and 6300 from AMD
And if you say the 6300 will win, really? A 1 module disabled 8350 is FAR ahead of the 6300
Look up, where?
Oh God... 6300 and 8350 is the same PD Architecture. A 6300 has 6 REAL cores. A 8350 is a 4 core or Module CPU that shoves 2 Threads down each Module or core which equals 8 "cores" displaying on your Task Manger.
Intel uses HT to Double cores, AMD uses Modules to do a less effective but similar job. I speak the truth. Or my Sources are ******ed.
r/madlads
YOUR sources are utterly ******ed.
PD architecture is module based none of the real core thing
If really a 4 core 8 thread AMD thing you claim AMD is doing then the 8350 will be very near a 6300 or probably even lose to it
because fact of a matter is, Intel HT doesn't work as well as we think it does and it only yields a little bit of extra speed like what feels like merely a extra core, something on the other of a 5th core
Discussion Starter · #17 ·
Originally Posted by d6bmg View Post
Your 3870K is good enough not to bottleneck your graphics card. (i.e. HD6950).
It's doing fine for one card, but I plan to add a second. That's where I feel the bottlenecking will occur.
1 - 17 of 17 Posts
