I have an Athlon 64 2800+ on a DFI LanParty UT NF3 250 Gb. My CPU temp reads about 38C non-overclocked under minimal load, and up to 49C under high load. From what I understand, that's pretty high. However, I actually undid the case and felt along the CPU heatsink and felt no excessive heat. It didn't even feel hot when I felt along the back side of the Mobo PCB and it felt room temp. The only thing that felt a little warm was the NF3 Chipset (which has only a small heatsink and no fan) and the power supply feels a little warm. My case has a fan on the side, and one on the top, one sucking and one blowing. It also has a 92mm fan sucking from the back. The CPU heatsink is stock, but 64 stock 64 heatsinks are supposed to be sufficient from what I understand, and it feels like it's no more than 28C anyway. Is anyone else having this same problem on the LanParty UT? I'm getting a new heatsink with fan for the chipset and I'm upgrading the rear fan to a 120 mm. Anyway, could this just be that the comp reading the wrong temp? The temp display on my front panel shows 71F which is about 21.6C. So what's the deal?
