As you might have seen we are trying to rally folding power! and if you have a OC C2D or Q2Q or just a i7. You should think about setting up the smp client and running it when you aren't on the PC! it will help alot! and doesnt take much to run it! anyone over 3 GHz will be a huge producer! under that is still a good producer thats where i fall for right now and im still getting good points!
any questions just ask!
Fold For The Cause
for the cpu (smp) clients, you can run them while using the computer aswell. I run 2xsmp clients nearly 24x7 (only shut them down when gaming). I run the gpu client aswell, but i shut that off anytime i am actually using the comp, as it causes a small amount of stuttering if i do anything while its running.
Overclock.net
