1 - 10 of 10 Posts
Is there ANYONE other than Logysis that makes case lighting??????
I must be on my 6th or 7th frickin logysis lighting package. They are amazingly low quality and seem to break, burn out, or whatever on a near constant basis.
I just want 1 blue cathode or equivalent to light up my TJ 07. Nothing super fancy. I have a rocker switch that I'd like to be able to incorporate into the lighting. Had to do some custom wiring for the logysis kit but it was doable.
Thanks!
Lian-li makes LED light strips.
· Premium Member
Thanks!
Lamptron sells CCFL http://www.lamptron.com/products/lighting/
· Premium Member
I'd go with LEDs over Cold Cathode. Cathodes usually have a pretty short life, and most are made pretty terribly. NZXT has a nice sleeved LED kit, as well, you could always buy SuperFlux LED's, which are very small in form factor but produce a LOT of light.
Originally Posted by Bear907;12973037
How's about this or this?
I can personally vouch for the NZXT kit. I stuck a white and blue 2m kit in my rig last friday. Funny I should come across this thread as I was just about to post a new thread with the photos I took from the build.
Check back in about 5 minutes to see the new thread.
EDIT: The thread is up: http://www.overclock.net/case-mods-general-discussion/981696-nzxt-sleeved-led-lighting-job-haf.html
Achieved with a set of 2m blue led's and a set of 2m white led's.
Haha! I thought this thread said, "High quality lightning??".
Anyway, are you using this? I just bought that from Logisys and it works and looks great!
· Premium Member
CCFL's are hardly high quality. They produce a lot of light and that's about it. LED's, especially Superflux are far better in light balance, quality of light and energy use.
1 - 10 of 10 Posts
