1 - 1 of 1 Posts
Hi everyone!
I just built a mini-ITX system last night and was starting to get concerned by the high CPU as well as NB temps (~60C at idle in BIOS). I have now installed all drivers and updated to the latest BIOS and things seem more reasonable (~45C idle in Bios, for both) but I am still concerned about WHY the voltages are so high at default settings on this chip/mobo?? I am seeing folks run less voltage overclocking to 4-4.5Ghz on forums than I am running out of the box.
I am seeing 1.4v CPU and 1.275v NB
Whats even more funny is if I slap on the first "easy" overclocking profile of 3.8Ghz in BIOS the voltages for both CPU and NB go down...***
What the heck are the default TRUE voltages I should be seeing, so I can at least set them manually before I get into overclocking this thing...
System:
ASRock FM2A88X-ITX+
A10-7700K w/ Cooler Master Hyper TX3
Corsair 430W PSU
8GB 2133 Kingston Hyperx on XMP profile 1 (1.6v 2133 - all other settings in BIOS are factory at this time)
http://imgur.com/AYVMSBQ
Thank you!
1 - 1 of 1 Posts
