1 - 5 of 5 Posts
my question is what one thing do you think i could upgrade or add on to my system to make my video card score higher?(im not counting the CPU score)<br />
<br />
also is it even possible to raise my score without adding another video card?<br />
<br />
here is my 3Dmark06 score on default<br />
<br />
total 5084<br />
-----------<br />
2.0 2322<br />
3.0 2584<br />
CPU 1033
Warcat or Omega drivers with the combination of overclocking.<br />
<br />
Watercooling for your GPU, or an after market cooler.
You have a XTX ther isnt much you can do in 06 short of a dual core (since its made for them) or SLI or crossfire. Up the voltages i on your card in ATI toll get an aftermarket HS and clock that badboy
Discussion Starter #4
so if i was to get a E6300 and replace my 3700+sandy would my video card's performance increase at all?
Not really, but your benches would skyrocket. At some point, in resolution, your CPU pretty much ceases to matter. An AMD/Conroe dual core at 2.6Ghz can pretty much outpace any GFX card's output at res's above 12x10. <br />
<br />
Anything after that is all e-penis and benches. (Like my 3,0GHz long opty penis... useless in gaming. I just wanted 3Gs)
1 - 5 of 5 Posts
