1 - 20 of 145 Posts
Twin Turbski
Discussion Starter · #1 · (Edited)
This one is just for fun. I know userbenchmark gets a bad rap from within the tech community, in favoring Intel, but I still think it still holds some comedic value and plus it doesn't take a long time to download and run.
So to be clear, we will not be taking this as seriously, however I will still use your scores (percentile rank relative to similar hardware) to determine your placing on the leaderboard. Remember, you are not competing directly against other forum members here. You are competing against OTHER identical hardware in the userbenchmark sample pool.
Go here to download userbenchmark:
Home - UserBenchmark
Run the test and then take a snip and post it here, with your percentile rank with like hardware, and any other details you might want to include.
Please also post a direct link to your results in your submission (not mine).
Asus ROG MAXIMUS X FORMULA Performance Results - UserBenchmark
Current leaderboard
Font Parallel Screenshot Number Rectangle
Smile Eyelash Font Rectangle Circle
Reactions: dagget3450
Twin Turbski
UserBenchmark is fine so long as you aren't comparing between Intel and AMD and only amongst your own pieces of hardware.
It's useful in finding out how much above stock you are managing to achieve, or whether you're being bottlenecked for some reason.
Yes, could not have said it better myself.
I have found with these competitions you almost need to bash userbenchmark in order to get participation otherwise you will lose all credibility. But, yeah I agree with you completely.
Twin Turbski
I found the run from my 9600KF (but I cannot find the link)
Edited July 7 by Storm-Chaser
I’ll post my KS later today, nbr1 spot in the g-skill 6400 ddr5 chart
Reactions: storm-chaser
Twin Turbski
I generally update the leaderboard with a new post to measure where I left off, so I don't miss any submissions.
I will also go back and update the original post as well.
Rectangle Font Parallel Technology Circle
My god these guys are cancer:
Font Screenshot Terrestrial plant Document Parallel
Apparently my 850 evo is long in the tooth. Or ready for the bin 🤷‍♂️. This is obviously with no raid and my mediocre 5600x.
Font Rectangle Material property Parallel Screenshot
2nd to none, I know….
Maybe a bit under the weather, It’s cheeks looking a bit pale… :)
  • Love
1 - 20 of 145 Posts
