O_O what stepping? also if that cpu's been nicely burned in just put .5 more vcore and see how high you can get im curious
Originally Posted by Chosen O_O what stepping? also if that cpu's been nicely burned in just put .5 more vcore and see how high you can get im curious ![]() |
Originally Posted by kitt3 Aww, i tried ..... fsb 269mhz divider 333mhz vcore 1.515v Vdimme STILL AUTO Timings are on defualt or auto HTT x3 then i tried to run 3dmark 01 and it crashed after 12 tests. |
Originally Posted by kitt3 great some1 replayed bah lol. ITs been 8 houre iam working on all methods tryin to hit 3.0ghz without any success. Well lez go step by step. Ill drop the divider to 266mhz is this fine ? |
Originally Posted by kitt3 in conclusion for ur post i should use the follow 273fsb 200mhz 1.55vcore Auto vdimm x3Htt correct? Edite* u know what, once i overclock the cpu in any kind of methods , once xp loads and fully starts up i bench for 3dmark01... there it always crashes at filtering texture test, dunno why y i have almost tried 100 method for gettin 3.0ghz. But ill keep fiting back like a DOG ![]() |
Originally Posted by kitt3 well i start the settings in my last post , and it crashed on 3dmark01 on same damn test always single texture ........ okay ill try wat u said above meh. |
Originally Posted by Xavier1421 Isn't his ram TCCD?? I thought I looked into buying OCZ Plat Rev2, because it WAS TCCD. If it is tccd, he should be running 1:1 at 2.7 or 2.8Vdimm, at about 2-3-3-10. His ram is not the issue here, IMO. |
