1 - 4 of 4 Posts
Ok when playing CSS i get random crashes. When i join a server on Garry's Mod, I get this crash also.
Out the Event Log
Faulting application name: hl2.exe, version: 0.0.0.0, time stamp: 0x4c525184
Faulting module name: client.dll, version: 0.0.0.0, time stamp: 0x4c87b974
Exception code: 0xc0000005
Any Suggestions on how to fix this??
Cheers
ReverbDP
Hardware Aficionado
Sounds simple but first thing to try is logout and log back in (I get similar problems if I stay logged in for a long time or log in to several pcs during a short span of time). Failing that and assuming you haven't done any recent driver updates or hardware changes - reinstall.
I fixed the Garry's Mod crashing by deleting the contents in the Lua Cache folder
garrysmod/garrysmod/Cache.
I was then able to join.
The server owner reckons it was a addon on the server causing it. But would that be anything to do with CSS crashing? it was the same type of crash ?
I haven't tried CSS yet since, i will do now.
i have a similar problem playing tf2 i will alt-tab and when it reloades a black screen pops ups and says hl2 stop responding it will even do it when i load tf2 for the first time
1 - 4 of 4 Posts
