1 - 11 of 11 Posts
Well, it says on that page how to get the multiplayer, so its fairly self explantory...
but here it is anyway. Or you can just look at the link.
Step 1
Navigate to the directory containing Steam.exe
Step 2
Then goto SteamApps/YourUserNameXXX/half-life 2/cfg
Step 3
Create a new text file and name it servermode.cfg
Step 4
In the file and the following
net_start
sv_lan 0
deathmatch 1
maxplayers (whatever you want)
Step 5
Save the file and load up Half-life 2
Step 6
Open the console and type exec servermode.cfg
Step 7
Now in the console type map <mapname of your choice>
Step 8
When it loads up open console up and type restart
Discussion Starter · #8 ·
Originally Posted by setite
where... because i see no menu for it
:swearing:READ MY POST!!!! Or the link I gave!!!!
You have to get to it through the console.
which is ******ed.. i get the post... but it should be in the regular menu... not worth the extra work when CS is so much better
1 - 11 of 11 Posts
