1 - 12 of 12 Posts
Could this be acurate? I just installed my Athlon X4 640 3.0 ghz chip and its running temps of 18c!!!
My phenom 9750 X4 was idle at 40c
Which program are you using, what are your ambient temps, what is your voltage?
It's most likely a mis-read.
What are your ambients? Because if it's lower than that you definately have a sensor problem (software or hardware).
Originally Posted by Bugs View Post
checked my bios and it showed 35c so cpu hardware monitor was wrong
The Computer Guy
1 - 12 of 12 Posts
