The pump Im lookin at is the MCP655 one. And I was only wondering whether or not to make homemade because today my bro's XSPC 2X5.25 reservoir w/built in pump cracked and leaked all over his DVD drive. And I was looking to avoid this at all costs.Originally Posted by tsm106;13005954
There are a lot of good quality res' for reasonable prices. Unless you're really good with acrylic type materials, I'd say buy one. You got the cylinder type that are pump independent and ddc pump type res, my two fav are the mcp35x res top and the bitspower minitabk plus. Well, there's D5 combo types too.
What sort of pump are you going to use, D5 style or DDC style?
actually i dont understand, home made reservoir how come it can be a problem.Originally Posted by tsm106;13005954
Thanks for the input! Plus rep to you!Originally Posted by somebadlemonade;13006660
then stay away from acrylic reservoirs and pump tops. . . they tend to crack with uneven pressure is applied
Dude, thanks for this idea, i do believe Im going to do this! Plus rep to you! Also sorry for the double post. Ill use a glass mason jar after drilling 2 holes into the lid! Itll look sick in my PC ESPECIALLY filled with ethylene glycol coolant!Originally Posted by bmaverick;13011174
I've been using my 1-gallon glass pickle jar RES for a little over 10 years now. Just poke two holes in the screw on lid. Then add two grommets to the holes. Next slip the tubing into the grommets. One tube will go near to the bottom while the other sits about three inches down inside from the lid. No leaks, no mess and you can see inside. The glass helps with the cooling effect.
You can even use a Mason canning jar too!
The cost is less than $5 for a DIY RES. Even cheaper if someone bought the pickles and gave you the jar.![]()
Avoid plactic jars since those are often bio-degradeable plastics over time. Your loop will get cloudly using plastic food grade containers. The only plastic would be dishwasher safe tuperware or rubbermaid containers. But then you are talking about $12-$20.
i should mention it's more about pump tops, and block tops, where you are screwing 2 different things together, an acrylic res on it's own, is fine, the pumptop res's are the ones that like to crack on youOriginally Posted by pyro_dude;13018035
That makes sense. Thanks for the info tho!Originally Posted by somebadlemonade;13018742
Originally Posted by pyro_dude ![]() Itll look sick in my PC ESPECIALLY filled with ethylene glycol coolant! |
