1 - 9 of 9 Posts
is there any way to make a good/easy Radbox for dual 120.
SNERP!!!
<tr>
<div>
Originally Posted by <strong>FpS-Sean</strong>
</div>
<div style="font-style:italic">is there any way to make a good/easy Radbox for dual 120.</div>
</td>
</tr>
</table>
</div>You could make one out of almost anything. Plastic, metal, wood....
Here's Burns work log on one...<a href="http://www.overclock.net/case-mod-work-logs/120172-project-2-heatercore-4-fan-pump.html" target="_blank">Project: 2 Heatercore, 4 Fan and a Pump Box! - Overclock.net - Overclocking.net</a>
Discussion Starter #4
well im just wondering is there anyway to install a dual 120 black ice pro rad and 2 120fans on the back of my dual 120 rear fan case!<br />
<br />
Rad doesnt fit inside but fans do.
May-be this...<a href="http://www.svc.com/mcb120k-blk-28.html" target="_blank">Swiftech MCB-120 Black 120mm Radbox Kit</a>
SNERP!!!
Drill some holes for the tubing and get some screws to pick it up off the case.
Something like this?<br />
<br />
<a href="http://www.overclock.net/faqs/118766-how-build-performance-shroud.html" target="_blank">http://www.overclock.net/faqs/118766...ce-shroud.html</a>
Discussion Starter #8
yeah i know, but is there anything else but that expensive that i can use..<br />
<br />
o_O
4 long bolts, washers, nuts and cut Bic Stick pens for spacers. Paint the pen tube spacers black and only you'll know that it's a ghetto mod.
Reactions: fstfrddy
1 - 9 of 9 Posts
