What should I name my water block!
  • cheap-the-heat
    Votes: 7 15.2%
  • cheetos!
    Votes: 15 32.6%
    Votes: 1 2.2%
  • sheat!
    Votes: 6 13.0%
  • pure sheat!
    Votes: 17 37.0%
21 - 37 of 37 Posts
AMD s939 LVL 99+
Originally Posted by Shrimpykins
Was looking for temp comparison's, not that you had an actual block. Also, depends on your definition of "awesome".
Alright, I was just proving both kinds of evidence to satisfy what you were asking, I will edit for content. Yeah, awesome doesn't describe it, I'd say my rig is, "functional and easy on eyes" Better describes it status. I can see from other perspectives tho, my rig probably looks like sh**.
OT: What is the status of this homemade loop? I hear the hose you'd use for like dishwashers and such is real good. Doesn't leak but it doesn't bend either, lol.
EDIT: Can we get some pics of the materials you have? Like, whats this $10 piece of copper? I'm pretty interested in this man.
Pics or it didn't happen.
pics plz so i can beable to name it from the options in the poll
Discussion Starter · #28 ·
Discussion Starter · #33 ·
still thinking... Hows big is that block?
my block of copper is thick 2"x1.5"
Thickness:1 inch LOL
weight 1lb
did you use a backplate I'm thinkving if making one.. but I'm lazy and I WANT TO PLAN alot
I went abit over budget I'm going to restart over :/ I was too lazy to read the label on the pump 0ft 0m head pressure lol 600GPH!
at some point you have to ask yourself
what is my time worth , really!!!
swiftech 320qp 49.95
http://www.sidewindercomputers.com/swmcqupo3xbl.html
X2O 750 Dual 5.25in. Bay Reservoir Pump 54.95
http://www.sidewindercomputers.com/x2o750du5bay.html
HEATKILLER� CPU Rev3.0 1366 LT 59.95
http://www.sidewindercomputers.com/h...lerlt1366.html
Bitspower G 1/4in. Silver Shining Fitting for 1/2in 2.50/each (need 6 for basic loop) 15.00
http://www.sidewindercomputers.com/big1sishfifo.html
thats 2 for rad, 2 for pump/res, and 2 for cpu block
Nylon Hose Clamp Size F - Black 10/2.00 (you only need 6 but its a deal)
http://www.sidewindercomputers.com/heclnyhocl0t2.html
Silver KillCoils by iandh 6.95
http://www.sidewindercomputers.com/sikibyia.html
Scythe 120x25mm SlipStream SY1225SL12SH - 110 CFM 7.95 each (get 3)
http://www.sidewindercomputers.com/sc12slsy110c.html
thats 212.65 plus shipping to you depending on where you live and how fast you want it.
and its a good loop, and your done in 1 evening
almost forgot the .89cents for a gal of distilled water
I understand the price difference but in reguards to how much time did you put into that
I work 6 days a week sometimes 10+hrs a day
my time is worth alot to save a little money but spend days working on it, I cant justify that.
A pet project just to do it ok but in all reallity its hard to justify that kind of time
21 - 37 of 37 Posts
