1 - 19 of 19 Posts
Main Components
Case : Caselabs Th10
Cpu: I7 2600K
Motherboard: Asrock Z77 Extreme 6
Gpu: Inno 3d Gtx 680 in Sli
Ram: 16Gig Gskill Sniper 1866
Psu: Corsair Ax1200
Watercooling Components
Radiators: 2x Xspc Rx480
Cpu Block: Swiftech Apogee HD (Black)
Gpu Blocks: ....Still waiting on these...
Tubing: Primoflex Black 3/8ID 5/8OD
Fans: 17x REEVEN COLDWING
Fan Controllers: 2x Lamptron Fc8
Reservoirs / Pump : XSPC X20 750 5.25" BAY RESERVOIR PUMP
*****Progress so Far*****
Front
700
Side
338
Little Theme park bend on tubing
338
Hard drives that will be going in this beast
338
Waterblock
338
Gtx 680s on standby
338
Discussion Starter · #2 ·
Trying to get hold of some more parts for the case hope fully i can get them. This is what i hope the front looks like when i am done
700
Dont mind the dodgy photo shopping
and in the top bracket will either have holes in it for some toggle switches or i will have just a small mesh piece in there to clean up the
front.
THIS LOOKS BEAST!!!! I like the yellow with the black
i wish i had the time and money (plus the space for such a huge case!) to do these mods and water cooling
Love the case either going to get this case or a Mountain Mods U2UFO Case. Do you think the price was justified with the quality of the case?
Discussion Starter · #18 ·
Hardware / Update time
Cpu: 3770k changed from 2600k (Running 4.7ghz 1.28v)
Motherboard: Z77 Maximus V Extreme changed from Z77 Sabertooth
Gpus: 3x Gtx680
Ram: Gskill sniper 1866mhz
Psu: Corsair Ax1200
Hardrives: 2x Plexator m5 pros 256mb ssd, 2x Corsair force gt 120gb, 2x Caviarblacks in raid 0, 1x Hitatchi 2gig storage drive
Monitors
27" Samsung A750D 120 HZ (1920X1080)
27" Asus PB278Q (2560x1440)
Audio
Headphones are Byerdynamic Dt880s
Sound card is ASUS Xonar Essence STX
Watercooling
4x Xspc Rx480
1x Xspc Dual D5 pump res combo
39x 2000rpm Reeven coldwings fans on lamptron touch fan controller running at 40% so they all run at 900 rpm
On desk picture
Changing out to red really improves the looks.
1 - 19 of 19 Posts
