1 - 5 of 5 Posts
Hello hello,
So I've just finished getting my Crucial M4 128GB SSD installed updated. And working fine. Now I want to re-hook up 2 HHDs. What is the process to get them to show on My computer? I also want to totally wipe the data and use them as my download/install drives and use my SSD as just my OS and used for a few extra programs.
Overclock Failed...
Just plug them into the appropriate ports (SATA, iI would assume?), be sure the ports are activated in the BIOS (and that the drives are NOT boot devices in the BIOS), fire up the computer and format the drives.
You can copy off any data you want o save before you format the drives.
So I ran across a issue...
I plugged in my two drives, and When I booted I went to BOIS. Set the SSD as the ONLY boot option. Restarted the system. Somehow my old HHD took control and booted windows anyways. I thought I plugged it in currently.
I miss placed my User manual so I'm a little lost.
The SATA port 1 and 2
With the Mobo mounted is the top port 1? Or is the top port 2? I have the SSD on the top port and what I believe is the drive taking over as the bottom..I'm gonna try and flip them. So I'll be back shortly to check for a reply.
1 - 5 of 5 Posts
