1 - 16 of 16 Posts
Hey guys,
I just purchased two XFX 5850's. One is an "XXX Black" Edition, and the other is the normal edition (interesting side note, the normal edition seems to be longer than the overclocked XXX one o_O )
But my problem is, when I run one of the cards individually, I get a solid 40-60 FPS in Bad Company 2. But when I crossfire the two cards, I get 15-20 FPS! This is with the latest catalyst drivers.
Is this a known issue, and is performance better in 10.5?
Pinoy po mga koya
this is a known issue for 10.6 (lags on bad company 2) although there are other games with big gains at 10.6 especially with crossfire/multi gpu configurations. if you're playing bad company 2 then stick with 10.5, if you're not playing BC2 then id strongly suggest to update to 10.6
weird thing is im not experiencing slow downs on BC2 with my 5970 @ 10.6. if you really want it to work try driver sweeper and reinstall the drivers again. I think the effort of making it properly work is definitely worth it. there are nice performance gains in 10.6 especially in 3dmark vantage
Hey thanks for the reply,
I just updated the CrossfireX profiles, which has helped considerably, but I'm still not getting the FPS I think I should be with 2 5850's - about 60-70 FPS with the lowest AA and AF settings at 1920x1200.
What games does 10.6 benefit the most? I play BC2 quite frequently, but if the pros outweigh the cons I'll stick with them.
Pinoy po mga koya
3DMark Vantage
Overall scores improve up to 5% on a single ATI Radeon HD 5970
Batman: Arkham Asylum
Performance improves up to 5% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 10% on CrossFire ATI Radeon HD 5970 configurations
Aliens vs. Predator DirectX 11 Benchmark
Performance improves up to 4% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 3% on CrossFire ATI Radeon HD 5700 Series products
Company of Heroes - DX10
Performance improves up to 7% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 5% with single card and CrossFire ATI Radeon HD 5970 configurations
Crysis Warhead
CrossFire performance improves by up to 7% on ATI Radeon HD 5000 Series products
DiRT 2 - DX9
Performance improves up to 10% on single card ATI Radeon HD 5800 Series products
Performance improves up to 10% on single card ATI Radeon HD 5970 configurations
Performance improves up to 4% on single card ATI Radeon HD 5700 Series products
The Chronicles of Riddick - Assault on Dark Athena
Performance improves up to 15% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 13% on CrossFire and single card ATI Radeon HD 5970 configurations
Performance improves up to 8% on CrossFire ATI Radeon HD 5700 Series products
Unigine Tropics
CrossFire performance improves by up to 8% on ATI Radeon HD 5000 Series products
World in Conflict
Performance improves up to 6% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 8% on CrossFire and single card ATI Radeon HD 5970 configurations
Wolfenstein
Performance improves up to 18% on CrossFire ATI Radeon HD 5800 Series products
Performance improves up to 18% on CrossFire and single card ATI Radeon HD 5970 configurations
Performance improves up to 11% on CrossFire ATI Radeon HD 5700 Series products
found this on another forum. I've only tested alien vs. predator and 3dmark vantage. alien vs. predator is about 3-4% gain for me but vantage was spectacular. more than 20% gain for my 5970. I barely hit 26k on 10.5 now im getting 29k-30k on 10.6
Wow, impressive. I guess I will stick with 10.6 for now, at least Bad Company 2 is playable now with the updated Crossfire profiles. Any idea what kind of frames I should be expecting with 2x5850's?
2 5850's at stock settings would be exactly where your at.
I have my 2 5850's at 900/1200 and get 70-130 frames a sec.
But i'm on 10.5
Originally Posted by BeepBeep View Post
http://www.rage3d.com/xmp/
App profiles in this order:
Install 10.6
Install June 18
Install June 23rd last
FPS is back up to 100-120+ maxed out in BC2 with 2x5850
june 23rd ???? last ???
But i'm on 10.5
Im running the 10.5 ( i think ) and i get between 70-120FPS in BC2 multi
bingo.
1 - 16 of 16 Posts
