Hot out of the box
1289 Views 30 Replies 14 Participants Last post by  Choggs396
Just a little info for ya all, if you have any video cards or anything with a heatsink, and its runnging hot stock,/loaded/.
You can take the heatsink off, and clean the garbage tape off, and apply some nice thermo past, ta da,then you will run much cooler. Providing you have nice air flow in the case.
1 - 20 of 31 Posts
^ that
^ that
^ this
I just figured i would say it cuz alot are asking about temps. Thats all lol,
hehehe
is there any how to threads here on OCN? I'm tempted to do it but I haven't got a clue
Originally Posted by BCC View Post
What card is it
I've got the 5770 xfire setup and some AS5 and MX-3 which one would you choose?
any links on a how to for gpus, the whole nine yards
Not that i can think of, i just removed the face screws, and for the back heatsink it has push pins, all you need is a small philps and a good pair of needle nose pliers. It is really simple. They come apart very easy.
Likely won't make much difference, I've replaced TIM on a number of Sapphire cards (MX2, AS5, NT-H1 etc) and it never did much. Sapphire already uses good TIM
I have two sapphs, max temp on both are different almost 10C different, I'm guessing one needs better TIM or the other is just getting the heat from the bottom card
Nope the main card is gonna be hotter allways,
1 - 20 of 31 Posts
