Hot swapping HDDs?
283 Views 3 Replies 3 Participants Last post by  UndertheGun
Are all SATA drives hot swappable?
1 - 4 of 4 Posts
I'm fairly confident that all sata II hard drives are hot swappable, but the motherboard might not support it, and depending on the raid/non-raid setup you have, you need to make sure it is supported.
Here's a previous post from our boards:
http://www.overclock.net/hard-drives...swappable.html
Looks like you have to make sure you're using the sata power cable and not the molex if your drive has both.
As long as they are running AHCI and not a SATA emulation as XP sometimes did? I think. I know hot swapping is a SATA AHCI function and part of what makes it SATA.
1 - 4 of 4 Posts
