1 - 9 of 9 Posts
how do i get to bios, i forgot, i want to oc my ram. How do i do it. cosair pc2700.
When you boot up, you should see something that tells you what key to hit to enter the BIOS. Also, add your motherboard to your specs; it helps us help you more easily!
northwood mobo
Discussion Starter #4
so i go into bios and senothing abut my ram, just the amount have 2048 nothing about tring to oc it, also its american megatrends
Dude...you got a DELL?!!!
Discussion Starter #6
its a sony
Just as bad...get some new MOBO...but I doubt you'll be able to use your recovery disk to reinstall your Windows...you might be stuck
Discussion Starter #8
well i'm building a new comp right now, and selling this one.
good deal...
1 - 9 of 9 Posts
