1 - 3 of 3 Posts
Guys,
Where do I buy these in the US? I tried searching but all I got was www.itaktech.com but seems not updated (Cant find Rival 600 ones/neither their other products like the bungee)
If Takasta on ebay AKA itaktech.com doesn't have feet for the particular model you're looking for, it's probably the case that Hotline Games are not producing it. You can buy smaller feet (ie3.0/g1) since they're compatible with most mice, or in my opinion, just use the default feet because most of the time the difference in glide is pretty minor.
About the bungee : you get it from amazon or aliexpress. I don't think Takasta sells them either.
1 - 3 of 3 Posts
