1 - 9 of 9 Posts
Wat
When I had my h50 on my 920 I had just about those same temps. If you want, you could turn HT off and shave off quite a few degrees, mainly on your load temps. But with the temps you have, I wouldn't bother. Looks good.
Depends if you run prime95 64bit small fft its hotter then ibt on max mem.
1 - 9 of 9 Posts
