Originally Posted by FtW 420
The rads will still put out the heat, the PC will run cooler but the room won't.
The room has it's own window AC unit - my den is also where I have my two fish tanks...thus the lights from my reef tank can heat up the room. In Mid July I bought a window AC for that room and it was oh so sweet.
Originally Posted by PCCstudent
Aqualoon, I see where you get your 'Avatar".Are you heading to the "Dells" or someplace in Minn.? Has the ppd on your 6.29 setup worked its self out (from your previous post?). One thing I have found with working through 'issues' involving folding is to make a change then be really sure you have given enough time for things to 'sort out".
Actually my username and avatar came from my other hobby forums - Monsterfishkeepers.com to be specific
And I am so not a fan of the Dells!
The PPD on the 6.29 seems to be coming along where it should, first time running it so not exactly sure where I should be. Going to give it now a week or so and then compare it to what others with same/similar CPU's are at.
I see you also found 3.8ghz for your 955, it is a very comfortable overclock for my cpu as well. For me I get my a3's done in about 8.5 hours and never have a crash due to an OC. What Vcore did you decide to go with and how is the H50 handling temps?
I actually went down to 3.74 @ 1.39v, to keep a solid 3.8GHz I had to put it up to 1.43...granted not too big of an increase, but I'm trying to stay cool
. As for my H50, just today I bought some new fans for my case and H50 and some new TIM (currently using TX3 - bit thick for my tastes but wanted to try it out). When folding I reach 53C, while gaming I never go above 46C...hoping to knock off another 1-2C from those temps with the new fans and TIM.
Real nice sysyem component selection except we must somehow get you on Win 7 (unless you have become really attached to Vista). I have two copies of Vista with no home, they are emergency backup OS's.
I love my version of Vista...it's an extremely clean version of Vista w/SP2. A friend of mine that I met over on the Anandtech forums 6 years ago (he's not a mod for them) cleaned it up and made it extremely smooth. So smooth in fact that there isn't any need for me to go to Win 7 as that's where my Vista basically is. I've had 0 problems with it whatsoever (unlike my dang work PC's that have Vista on em).
And I may switch to an i5/i7 setup...not sure yet...the game I built this PC for seems to favor intel chips (go figure eh).
