1 - 20 of 24 Posts
I was looking for some bassier headphones that were a bit higher qualtiy and came across the AKG k81's.
I was wondering-
-will these work on my ipod nano 3rd gen w/o an amp?
-are these good headphones?
-if not other suggestions under $100
Thanks
I was wondering-
Thanks
1) Yes
2) Yes
3) Denon D1001 can be found for around $100 (maybe a little more) if you have patience to look for a deal.
K81DJ is an excellent headphone for portable application and specifically works well with Electronica, Techno, Downtempo, Ambient, etc.
Originally Posted by 20Driver07
I have a set for work.
AMAZING.
I would never change them for any other set of cans
I beg to differ
as everyone has stated they are very good cans. There are only a couple things that would keep me from saying they are the 'ultimate' 'budget portable can.
1. they do sound better amped.
2. bass is a bit flabby and mids are a bit recessed without a couple simple tweaks
3. the cord is way too long.
I say go with them now, then save up for a mini3 portable amp. Then get a better cable that is shorter and do the tweaks.
I'm pretty picky though so you can take my comments with a grain of salt... also my idea of 'budget' is what some would consider the most they would spend.
I think our ideas of budget components are beyond what most any normal person would spend
I have a set I use for work. While they sound great, the headband is kinda small and tight. First thing you'll need to do is stretch them out - do some searching online and there are some tips that help a lot. You'll need to stretch them horizontally (ear to ear) and vertically (top of the head) It took about a month or so for them to stretch out and get comfortable. My only other gripe is that the cable is pretty long. One of these days, I'll get a shorter one put on.
But, with that said, they sound freakin' awesome unamplified on both my Zune and my laptop. I'm very happy with them.
Discussion Starter · #13 ·
that's what i've heard
thanks
I've owned the K81DJ's for 2 years and haven't even considered buying another pair of cans since then. The long cord just started giving me problems a couple weeks ago. No sound out of the left side unless I move the cable around. Nothing a little cable doctoring won't fix. After dealing with the immense cord for all this time, a short cord will be a godsend.
As people have been saying: until you break them in, they get uncomfortable after 1-1.5 hours of wearing them. Otherwise, they're a steal at under $100 (I think I paid $70 shipped).
1 - 20 of 24 Posts
