1 - 10 of 10 Posts
I'm about to pull the trigger on my new build around the XCLIO Windtunnel Advanced when I saw that the XCLIO Blackhawk just showed up on newegg. Its only got one review so far but its a sexy case looks wise, a lot more attractive than the Windtunnel. My concerns are how good the blackhawk is at airflow and room--with only one review its hard to tell.
How is the Blackhawk compared to the Windtunnel?
Ah buyer's remorse. The Windtunnel looks like it can cool more considering those 2 Oversized fans on the side. Even if the Blackhawk had better airflow it wouldn't lower your temps by that much compared to the Windtunnel
I like the look of the Windtunnel over the Blackhawk, just personal preference though. I can't vouch for XCLIO cases though as I've only ever built in Coolermaster's. My main concern would be cable management with either of those cases you're considering. Have you looked around the For Sale section here? I've seen some decent cases for the money.
I had an X-Cruiser and it was awful..
XClio constructs their cases out of pretty thick steel, so the build quality isn't terrible, but don't expect anything from the dazzle element of them. I had a Windtunnel and within the first week all the LEDs failed, and the 250mm fans put out almost no air. My thoughts are that the fan controllers on the black hawk will be of similar quality, and you'll be left knobs on your computer that are just as useless as they are obnoxious.
Plastic is bleh to me anyway.
Interesting. I'm reading a lot of horror stories about those 250mm fans now actually, and then I see your post. As for the Black Hawk I was looking at--it was the red LED/Black finish version of the old $70 dollar blackhawk, and for some reason was inflated to $180 because of it. If I'm putting out that much money I won't get a reskinned low tier case.
1 - 10 of 10 Posts
