1 - 11 of 11 Posts
Hey, i know you can physically find out a CPUs stepping but can i find out by running a piece of software to find out?!
Thanks
-Chris
Overclockiit
Originally Posted by Mad_Handlez89
There is no software that can tell you.
Only way is to look on the chip itself
Sorry
Mad_Handlez89 is right there is no software available that will tell you the steppings on the CPU
Nope, afraid not.
Reactions: Sin100
Just out of interest whilst on this subject, Is the stepping like a batch number dictating manufacture date?
So all chips from the same wafer have the same stepping for instance?
In the Stepping such as 3700KAB1E0606
3700 - Is the model number as 3700+ AMD
KAB1E - is the actual stepping
0606 - this is the batch code as in date it was manufactured June/06
Just remove the Heat Sink and take a look, you know you want to
Maybe apply some AS5 if you haven't already
Reactions: Sin100
Discussion Starter #10
I really cba to be honest!
When i get my zalman CNPS9500 then i will be able to see whats on the ihs
Reactions: Sin100
1 - 11 of 11 Posts
