Originally Posted by Cretz
So because the video is a cartoon you dismiss all of the valid points it brings up? Thats just blind fanboyism. Of course the iPhones market is larger than the android market when a bunch of drones will buy anything with a lower case i in front of it.
You're just blindly raging because it has an i in front of it. What makes you any better?
You wanna do a spec rundown?
Let's list the winner in each category:
Battery Life: iPhone 4
Removable Battery: EVO
Screen Resolution:iPhone 4
Screen Size: EVO
Internet Connection: EVO
Apps: iPhone 4
Camera Quality: iPhone 4
Video Quality: iPhone 4
Form Factor: iPhone 4
Customization out of the box: EVO
Customization once rooted: Tie
GPU: iPhone 4
CPU: iPhone 4 (Don't even start comparing Mhz...)
In each case they're fairly close however with the obvious exception of gaming apps and battery life.
One has Android, the other has iOS. Pick your poison.
I was about to get an EVO, looked at about 15 stores only to find it sold out everywhere. I'm waiting for the Epic 4G, should be better than the iPhone hardware wise.
