1 - 20 of 54 Posts
the os is windows 7 ultimate 64 bit im looking for any ideas or solutions
Start > Run > Type "msconfig" > Start up tab > Untick any programs that you don't need to start at boot..
Also, in msconfig, go to boot tab and click "No GUI boot". It'll be a bit faster as it doesn't show the windows animation.
Hope that helps.
Discussion Starter · #6 ·
its cool i just said that so other people would still put in their ideas and thanks for the help
Originally Posted by psyside View Post
Control panel> power options, minimum processor power state 100% turn off all power savings.
High performance power plan, oc the CPU/FSB, turn off all power savings.
Latest Intel RST drivers for your SSD, firmware 002.
intell drivers for my crutial ssd and amd mobo/ processor? will that be ok on my crap
Originally Posted by mcg75 View Post
Your sig says you have an amd board.
Intel RST will not work with it because it's not an Intel board.
Go to your mobo manufacturer site and download the latest amd achi driver.
they're all the same..haven't been any changes in forever
be sure and use the x86 one..the x64 never works/causes bsod
Discussion Starter · #15 ·
i thought so after reading what intell had to say about there driver that is why i wanted a link
Discussion Starter · #19 ·
so far ive done everything and dont feel like i have the performance i should be getting so would the next step be to buy a better motherboard
1 - 20 of 54 Posts
