1 - 9 of 9 Posts
ZFS
Ok here's my problem. I need to install windows XP on the machine I'm on right now because it's in Chinese and cannot be changed.
Tools I have:
USB HDD.
USB Drive.
An iso of windows XP english that I ripped from my CD.
Can I just put the iso on the root of the USB HDD and it will boot it?
ZFS
Doesn't work. I think these EXE's don't work on the chinese windows I'm on right now.
ZFS
Discussion Starter · #6 ·
Originally Posted by Skullzaflare
if you extract the contiants of the iso to the root of te hdd, the computer can boot from it, ive done it with vista
Really? The external or the internal?
are you able to download a language pack and then set it to english? Iwould google search that first.
It just seems like there would ba a hotfix or something for a problem like this.
Reactions: redsox83381
ZFS
Discussion Starter · #8 ·
You can only change regional settings and such. Not the actual language.
ZFS
Discussion Starter · #9 ·
I figured it out. I extracted the ISO and then just ran the installation EXE. I am so used to installing from boot I forgot you could do it within Windows.
Thanks everyone.
1 - 9 of 9 Posts
