Welcome to
verclock.net Matt!!
You can download coolbits 2.0 (a registry edit that allows nVidia's own overclocking utility to be accessed from the video card control panel)
I would highly suggest finding an Arctic Silencer or similar (Zalman is good too).
If you don't want to purchase something immediately, you can try the case fan trick, but a new heatsink and fan will work best.
I moved your thread to the appropriate section of the forum, should get plenty of attention here.
