1 - 4 of 4 Posts
The game is fullscreen, so I can't see ati tool or overdrive, how can I tell what clock speeds my card is at? I suspect my clock speeds are not going up when I enter a game, but I don't know how to check if I am right.
As far as I know once the clock speeds have been set they will stay set.What you really want to know is your frame rate changing under gaming,correct?
Youre using ATItool to automatically overclock your GPU when you start a 3D application, right? well just set the option to play a sound when it does, that way you're sure it's on.<br />
Or get a second monitor <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />.
If you use ATI Tool then you can just click on "Show 3D View" and watch your clocks (and temperature) soar <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
1 - 4 of 4 Posts
