1 - 3 of 3 Posts
...get Windows XP to recognize a WD 80Gb HDD that has Xandros on it.<br />
<br />
I installed Xandros on a newer, larger HDD. The HDD in question is one that I would like to use as a data-backup drive in XP. How can I wipe it or format it? Will I have to re-partition it and leave the Xandros on it? If so what downloadable software is recommended (simplest is best for me <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> ))<br />
<br />
Also will the solution be able to be done via a USB interface?<br />
<br />
Thanks in advance for your help.
you could just partition it into two , eg 40gb and 40gb , install windows first then Xandros, then you can dual boot it without any problems <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>mootin</strong>
</div>
<div style="font-style:italic">you could just partition it into two , eg 40gb and 40gb , install windows first then Xandros, then you can dual boot it without any problems <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><br />
Hey, thanks!<br />
<br />
Okay, how should I go about doing that via USB, and not break any copyright laws (XP OS on 2 different systems - ugh!) ? <br />
<br />
I've never done a dual-boot HDD. I don't really need an OS on it, just that ability for XP to recognise the HDD and be able to backup data (my documents folder) to it.
1 - 3 of 3 Posts
