Phase/DICE/TEC is much, much colder than that. Also, condensation is more an effect of changing temps (as in ambient/vs cold) If the entire environement is the same temp, you should be OK.
Water vapor that naturally condenses on cold surfaces into liquid water is called dew. Water vapor will normally only condense onto another surface when the temperature of that surface is cooler than the temperature of the water vapor. |
