1 - 19 of 19 Posts
... Dont do it just go buy some from like frys or even worst buy.. not worth the damages to your CPU without the thermal compound heat transfer would be severely limited and probably result in damages to the cpu you saved like $5 bucks in thermal paste but lost 80 for a chip? =\\
Originally Posted by consume;12010471
Put in a new cpu whilst using the thermal paste already on the heatsink? I ask this because i have a cpu here....and no thermal paste yet....and well....you know.
Well it wouldn't be that devastating, just be sure to check the temps, and replace the TIM when you get the new stuff
Depends.
What TiM was used before, how much of it and when it was applied.
Surfaces of both, cpu and heatsink.
What you intend to do while having old TiM.
If tim is really old and some white no name crap, it could overheat easy and fast and would just shut down all the time.
If good tim was used and proper amount was set you could be receiving only few digits more than with fresh one.
Could be worse If heatsink is terrible and with heatpipes that touch socket and needs to be filled.
Just because you find yourself being mounted but a hot dirty hooker doesn't mean you should do her without a rubber.
Play it safe and pick up some paste.
Bowser Has Ryzen!!
Use some toothpaste in the mean time, colgate total preffered. Ok no, just kidding.
You will be fine for a short period of time, just dont go stress testing and benchmarking. Probably should enable cool n quite too.
Discussion Starter · #11 ·
I was actually going to get some toothpaste....
Tinkers With Rigs
Sigged!
Reactions: Dark
Discussion Starter · #14 ·
Originally Posted by mott555
What's the CPU? I've actually run dual-core Wolfdale chips without any TIM before and it was fine. Not that I'd recommend it though.
IT's a q6600 and i just looked at my current cpu (e6320) and apprently i put a ****load of thermal paste on....im rubbing some off with my finger and putting it on the q6600...talk about being ghetto..
Bowser Has Ryzen!!
Nah, if anything I believe it would hurt. Just cuz its minty and cool in ur mouth, not so much for cpu. Plus its grainy and Im sure contains lots of air bubbles, not good for disapating heat from IHS to heatsink.
In thoery your temps would likely be very bad, just go buy some new thermal Paste
1 - 19 of 19 Posts
