1 - 14 of 14 Posts
close to setting this thing on fire. I can't seem to find the settings within the bios to change my timings. And judging by what you see here, what do you think I should set my timings to, to get a higher fsb to become stable. I've been stuck between 840 and 860 on the MEM, and 1120 on the fsb.<br />
<br />
<img src="http://i21.photobucket.com/albums/b273/jcbzhnsr/ScreenShot001.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
all memory is different, but when timings come into play the lower the better. just try out different timings and test them.<br />
<br />
i mean my old memory was unstable at 2-5-5-7 ddr520, but if you changed the timings to 3-3-2-5 it was perfectly stable. just test a bit and see what your memory is comfortable at haha<br />
<br />
though, if you can't find it, your motherboard might not allow you to change memory timings.<br />
i think for some motherboards though, if you hit an F# button it'll show more features... like F2 maybe? i forgot which one it was.
tried, the only option I get is underneath the LDT settings for the morth bridge. It gives me options for the cas, ras, tras, and so on, then it asks for clock 1 or clock 2. Is this what I should be changing?
<tr>
<div>
Originally Posted by <strong>jcbzhnsr1</strong>
</div>
<div style="font-style:italic">tried, the only option I get is underneath the LDT settings for the morth bridge. It gives me options for the cas, ras, tras, and so on, then it asks for clock 1 or clock 2. Is this what I should be changing?</div>
</td>
</tr>
</table>
</div>Those are the ones: <br />
<br />
Here's a little help:<br />
<br />
<a href="http://articles.networktechs.com/printer-1.html" target="_blank">http://articles.networktechs.com/printer-1.html</a>
Discussion Starter #5
ahh, thanks guys. Now to figure out which timings to try first...
Discussion Starter #6
4-4-4-12 is better than the first post, right?<br />
<br />
<img src="http://i21.photobucket.com/albums/b273/jcbzhnsr/4-4-4-12timings.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
depends on your DRAM specs....
Discussion Starter #8
advertised as 4-4-4-12 timings on the xms2 package. My superpi went from 35.687 to 33.686 in the 1M category, I can't believe that made that much of a difference...
Try 4-4-4-15...post back...
Discussion Starter #10
tried 4-4-4-15, and my superpi 1m went slower. I also tried 4-3-3-3-12, and got my best results at 33.094
Discussion Starter #11
tried 4-3-3-3-10, but it seems slower in superpi. 4-3-3-3-12 worked the best. 4-4-4-4-12 worked second best. Would I be able to raise the fsb a bit now?
Discussion Starter #12
tried 3-3-3-10, but it would not post. Any suggestions from you gurus on what the best timings are for 4-4-4-12 rated corsair xms2 PC5400 675Mhz ram would be? Very anxious to set it best. Thanks for all your help guys.
Discussion Starter #13
ok, last thing, are these timings okay? And lastly, what ratio of fsb/mem should I shoot for when playing with intel chips?<br />
<br />
<img src="http://i21.photobucket.com/albums/b273/jcbzhnsr/4-3-3-6-8.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
Discussion Starter #14
bump
1 - 14 of 14 Posts
