1 - 3 of 3 Posts
Questionnaire galore!
Said in the Title
Need help now cause i'm having some problems
Originally Posted by Skillzero
You should be able to type msconfig in run and disable it to run at startup.
You can also uninstall it, read more here:
http://service1.symantec.com/Support...05033108162039
I just need to disable it for a while with no reboot cause i'm having problems insstaling FSX seems like the Norton Framework something is crashing when i insert Disk1
1 - 3 of 3 Posts
