1 - 8 of 8 Posts
windows 7 64 bit pro
and im not sure about the "minimisable start menu" part. this was just like this as soon as i finished this pc build and got drivers installed
I was on my phone at the time... I meant the auto-hide and lock task-bar options but i've just tried that and can't replicate the issue on my Win 7 Pro x64 PC
I assume you're running 1920x1080 resolution to your 1080p monitor?
What else have you installed and can you do a full screen shot so we can see everything?
What programs have you installed, is it feasible to reinstall windows and see what a vanilla install does?
Hey, I doubt this will work but try going into your gpu options.
I have a ATI card, so in my catalyst I would click on the flat panel properties & click on enable gpu scaling.
Then click on "scale image to full panel size". See if that works?
hmmm, okay, i dunno why, but when i woke up and checked this morning, it was fixed.
the opened window touches all the way to the task bar.
i didnt do anything to fix it or antyhing but its fixed.
i have no idea how it got fixed.
1 - 8 of 8 Posts
