1 - 3 of 3 Posts
Hi, i want to get 2 extra speakers hooked up, but when i select 7.1 it says that i have to attach 1 of the extra speakers to my sub/centre output. For some reason i only seem to get 1 channel out of my centre/sub output, because i plugged in a sterio 3.5mm jack which then splits into 2 rca connectors, and signal is only coming out of 1 of the rca connectors, i know the cable is fine because i get 2 channels from my other 2 outputs.<br />
<br />
Can somebody explain please
An rca splitter splits it to left and right, Say the sub is the right and centre is left if you use the splitter you will loose one of the signals and depending on which plug you use will be where the sound comes out be it left or right
ok, but i stil dont get why im only geting 1 channel out of my sub/centre output, because i tried my sterio speakers in the sub/centre output and only 1 of the speakers was working. Could i have a faulty sub output?
1 - 3 of 3 Posts
