1 - 2 of 2 Posts
Simple,
I'd like to make each folder have
Name, Size, Type, Date Modified, Dimensions. And I can't seem to apply it to the whole computer and it's extended harddrives (externals). I'd like to do this, apply to all, and be the all in all (regardless if it's a picture, video, or music folder, just one folder type, that's it, period).
I understand to "apply" this, it'll probably take all night, but i'd rather have the computer be that simple and adjusted to that simplicity, then do anything else.
Thanks,
- Le_Loup
Well, open your c drive.
Customize your views and options to how you want your folders to appear.
press Alt+t , and select folder options.
go to the view tab
click on Apply to folders
This should apply to all folders in your C-drive with your customizations
I dont know if these will apply to your extended harddrives.
You might have to follow the same procedure for other drives.
See if this works for you.
1 - 2 of 2 Posts
