How do I make my chair stop squeaking?
54016 Views 32 Replies 25 Participants Last post by  abrusil33
Deleted.
1 - 20 of 33 Posts
It could be squeaking for any number of reasons (and it could be coming from a different place than you think - I hate when that happens). But you can also try White Lithium Grease, which is specifically designed for metal-to-metal contact.
It depends does is squeak when you lean back? sit down? spin around? It could be coming from a number of different areas.
You must first figure out what is squeaking, then fix the problem, you will need some grease and a grease gun of some sort. apply grease to the squeaking are and viola squeak gone.
if you dont have grease, Vaseline works great too
I once used vegetable oil to get rid of squeaking in my chair. It's still working
Break-Free is a fantastic lubricant. Also motorcycle chain lube works well for squeaky things too. I've used both on my truck's clutch pedal when it starts squeaking and they both work great.
But, like the others said, figure out where it's squeaking from. It's also possible that a weld has broken and two formerly attached pieces are rubbing against each other.
Yea first find out what exactly i causing the noise, it could even be a loose bolt, then just put some grease in that area and WALLA fixed.
This works everytime.
Step 1: fill bathtub with oil. note: doesn't realy matter what kind of oil.
Step 2: throw chair in bathtub roll it around until completely saturated.
Step 3: take chair out of bathtub.
Step 4: sit on chair, no squeaks
repeat as often as necessary
lol?
I do this with my local strippers
Originally Posted by wallyworld96 View Post
Are you sure their isn't a mouse eating crumbs that you dropped?
really though, I always bounce my leg while I play FPS games and my chair squeaks. My girl will wake from a dead sleep at 3am screaming mad over it!
LOL that's really awesome and too bad for her. hehe
No grease or vaseline, than use spit!! Works just as great.
instrumental oil works good
Clean the area then re-lube
White lithium grease is the bomb. It won't drip, and takes friggin FOREVER to wear out, plus it's good for basically anything that needs lubing and that isn't organic/bodily.
uh yeah i tried that and well now my seat is soaked in oil. when i sit my butt gets all oily. was i not supposed to soak the chair because i threw it exactly as said in directions.
Oh I love this thread!
[email protected]"that isn't organic/bodily"
[email protected] oily butt
1 - 20 of 33 Posts
