how do i mount a disc image in windows 7?
1610 Views 24 Replies 25 Participants Last post by  Powelly
my normal image-mount (nero 7) is incompatible with windows 7, any idea how i could mount an image on 7, what program i'd need?
1 - 20 of 25 Posts
I'm not sure if it will work with W7 but Daemon Tools Lite is my personal favorite.
~B~
PowerISO works great for me in W7.. Daemon Tools would not work but maybe a newer version will.
Alcohol 120% build 1.9.8.7612 works for win7. PowerISO works also. MagicISO is a good program also, but I haven't installed/tested that one in 7.
MagicISO works fine in 7. I was surprised because I had heard rumors that daemon tools didn't work with the RC.
Daemon Tools and UltraIso are good apps also.
daemon tools lite works in win7 64 bit. i use it.
Originally Posted by gymenii View Post
Virtual Clone Drive
Works just fine and dandy for me in Windows 7.
I don't know why some people say daemon tools lite doesn't work with 7, but it works for me as of right now.
Daemon Tools would definitely work...
Been having issues with DTlite in 7. I didn't get a lot of time to mess around with it though. I will give it a shot in the near future.
MagicISO and it's free.
all I know is that the newest daemon tools lite didn't work FOR ME and made my win7 install not be able to see any of my sata dvdrw drives and I had to do a clean install to get them back. (note I'm not saying it won't work with win 7 x64, just that it won't work for ME)
daemoon tools lite is now compatible with 7.
virtual clone drive
During the early beta stages of Windows 7 it wouldn't work period....you had to turn to apps like Alcohol 120/MagicISO/Slysoft app's etc
Daemon lite is working fine for me atm
1 - 20 of 25 Posts
