1 - 19 of 19 Posts
I'd like to switch the 2 channels so the left channel comes from the right speaker, and the right channel from the left. Short of cutting the cord up and rewiring it, how do I do this?
Originally Posted by Jobotoo;14889100
If you have positional audio software you can move the placement of your speakers in the software.
But I would think your best bet is to switch the inputs.
The software won't let me change placement.
Forgot to mention, it's headphones. There's no way to switch the inputs.
Discussion Starter · #6 ·
Originally Posted by dealio;14889146
there is no native or freeware solution.. found this http://www.sobolsoft.com/swapspeaker/
i take it you will not swap the speakers or flip your headphones, why not?
also you can get 3.5mm to RCA adapters a flip the RCA channels
My headphones rotate like this (↓) but they stop when they're parallel with each other.
It's super uncomfortable to use them if I wear earrings, so I usually end up putting them on backwards so they aren't crushing my ears.
Originally Posted by dealio;14889222
plug these together,
LOL, awesome idea. I'll do that if I cannot find a software fix.
I know, this is an old post, but since it pops up as the first result in Google when searching for "Windows Swap Audio Channels", I thought it would be good to post a working, free solution here:
  • Download Equalizer APO from https://sourceforge.net/projects/equalizerapo/
  • Configure it to attach to your output device (Usually something like: "Speakers - VIA HD Audio" or "Speakers - Realtek HD Audio"); you can change this later with the "Configurator" tool from the Equalizer APO start menu folder
  • Create a new file in C:\Program Files\EqualizerAPO\config, name it for example swapchannels.txt
  • Paste the following line into it as its only content:
    Copy: L=R R=L
  • Save it
  • Open Equalizer APO's configuration editor
  • Make sure that your device is the correct one in the dropdown menu on the top right
  • If applicable, remove all pre-configured options by clicking the red "minus" icon (or, if shown, the button with two arrows pointing downwards, then "Remove")
  • Click the green "plus" icon to add a new configuration for your output device, then navigate to the "Include configuration file" option
  • Select your swapchannels.txt file
  • Save/Apply the configuration
  • Voilà!
tl;dr:
Install and configure EqualizerAPO for your output device with only one configuration file that has only
Copy: L=R R=L
as its content.
Hope this helps!
Fantastic work posting the fix for this. My nice headphones have the 3.5mm port coming straight out the BACK of the left cup and made my V-Moda Boompro mic unusable. This was the perfect solution and took all of 5 minutes to do. Thanks EdRoxter!!
    Copy: L=R R=L
  • Save it
  • Voilà!
tl;dr:
Copy: L=R R=L
as its content.
Hope this helps!
You`re awesome! Thank you very much? you just made my day! I`ve searched for the solution and nobody gave software issue! Just registered to THANK YOU and + to your rep - that`s what you deserve!
    Copy: L=R R=L
  • Save it
  • Voilà!
tl;dr:
Copy: L=R R=L
as its content.
Hope this helps!
this should be sticked thread !
thanks Edroxter !
i spend so much time on web to finally make a software solution !
thanks thanks thanks !
RET 0
    Copy: L=R R=L
  • Save it
  • Voilà!
tl;dr:
Copy: L=R R=L
as its content.
Hope this helps!
Adding to this, there's also a GUI tool called Peace that allows you to do various things without manually writing the code. In this case this is the option you want;
    Copy: L=R R=L
  • Save it
  • Voilà!
tl;dr:
Copy: L=R R=L
as its content.
Hope this helps!
Thank You sooooo much!
It helped. First time somebody not said "change the cable"...
You made my day/week or even more
    Copy: L=R R=L
  • Save it
  • Voilà!
tl;dr:
Install and configure EqualizerAPO for your output device with only one configuration file that has onlyCode:
Copy: L=R R=L
as its content.
Hope this helps!
Omg it works thank you so much man :D . Wish you the best my mate :specool:
1 - 19 of 19 Posts
