I have to set my receiver to manually play pro-logic. Even then, I really cant even tell if it is proper 5.1 surround sound.
Kind of strange that your receiver only plays through 2. Does DTS and the other surround sound abbreviations work properly?
EDIT: I bet it's your TV sending the signal through optical. Try connecting your wii directly to the receiver or through you TV with just the plain ol' red&white audio cables.
