1 - 16 of 16 Posts
Originally Posted by Sushimaster;13049408
What exactly did you do to disable speedstep, i tried to disable speedstep in bios but its still there
I disabled it in the BIOS. Now I see minor bounces +/- 10Mhz. It doesnt fall to 3.4Ghz anymore.
How do you check if it is still on?
have cpuz open when you are stress testing it... after a minute or so... turn off the stress test and see if the clock stays the same
if it goes down... speed step is on
Discussion Starter · #14 ·
After more testing, the multiplier still drops to 34 under load.
After rebooting works OK for 15 minutes on 100%, then it starts to bounce between 47 and 34. It stays about 12 seconds @ 47, then drops for 5 seconds to 34, and back to 47
According to RealTemp EIST is on after boot, regardless of the bios setting.
What should I do?
Make sure that the following are disabled in the BIOS:
1. That turbo feature that allows the multiplier to be increased by x1.
2. Speedstep.
3. C1E (or whatever you BIOS calls it).
Also make sure that the CPU is not throttling itself when the temps are too high.
1 - 16 of 16 Posts
