Originally Posted by
Ken1649
Go to CCC 3D settings > Catalyst A.I > select "Quality".
Then create a "preset" for BFBC2. For example "X".
- Step 1: Go in CCC 3D settings to set your settings for your specific game. Example "X" then save your preset as "X".
- Step 2 : Go in Preferences and go into Standard view to apply your other preferences in the other menus, example: Overdrive/colors etc, but don't alter the 3D as your already did this step previously. DO NOT SAVE.
- Step 3: Once all your preferences are done for your "X" game. Click Start at the top of CCC to select Preset. Click "add preset" and save it to the same name you did in Advanced mode "X". When prompted to overwrite, select "Yes".
Now your 3D settings will be applied and your custom Overdrive settings also when you select a specified preset for a game or whatever you need.
Go to verify the profile in: xxxx\AppData\Local\ATI\ACE\Profiles\ if all there, you can go back into Advanced Mode to click on your presets and they will now work
Create a keyboard shortcut ke for preset "X".
