1 - 11 of 11 Posts
hey so ive decided i wanto flash the BIOS on my 4770 to see if i can push the OC a little higher, ive downloaded the asus TOP bios but im not sure howto proceed, could anyone point me in the right direction?
I don't know how to on ATI cards, but for nVidia there's an application called nvflash-- grab the card bios using GPU-z, modify it with nibitor, then reboot in DOS and use nvflash to write it to your card and reboot again.
I'm sure there's a similar utility for ATI cards, I just don't know what it's called.
ok just got done, initially it seemed succesfull but the max resolution i can go is 1400x1050 as opposed to my monitors native resolution 1920x1080 and CCC dosent recognize the card at all
Nvidia Enthusiast
failed flash then, go back to stock one
Discussion Starter · #6 ·
weird thing though is this is right after i installed the windows update for SP1 and at the login screen before it applied it it seemed to be at its native resolution, could the update be causing some kind of conflict?
Nvidia Enthusiast
the bios you flashed to could have been corrupted or damaged somehow in the process
Discussion Starter · #8 ·
guess no extra OC for me :/
Nvidia Enthusiast
doesn't look like it
SUCCESS! on a chance i tried reflashing it and since there was no windows update to mess with it im now at 1920x1080 running 800/850 as opposed to the old 750/800, now onto some more overclocking
Nvidia Enthusiast
nice work
1 - 11 of 11 Posts
