Originally Posted by atomicfission92
I understand what you are saying. I just figured that it would cost me like a total of like $350to get my P180 water cooled. While that system I would have for $165 and already done. I do understand what you are saying. Can you make any suggestions for water cooling system for it. I want to cool my Cpu as well as my GPU. I think I saw a 360mm rad some where for like 50 bucks. not sure where though.
Ok I have a max of $300 to spend on a water cooling system (you've convinced me to build a new system, lol). I know you don't need that much, but thats what I have to work with, and I am willing to spend.
Dude...$300 is golden high end style.
Parts:
CPU: Swiftech Apogee go to jab-tech.com enter the coupon code "cryo-laboratory" at the checkout and get it for $39.95 shipped.
GPU: Danger Den MAZE 4 ~$45 w/ mountings. Tigerdirect usually has good deals on it
Pump: Danger Den D5 ~$75
Tubing: Masterkleer $.65/ft
Rad: go to an auto parts store and pick up a 77' Pontiac Bonneville Heatercore for about $25. You'll have to cut the ends off the tubes and then soak your tubing in hot water to stretch it over the heatercore tubing, but this is by far the best bang for your buck. It is much better then a lot of rads out there.
Tline: get an extra bit of tubing, a danger den fillport, and a T fitting if you like and make one of these or buy a res. $15-25
Plastic clamps, random stuff $20-30
Basically that is the best your money can buy. I you can wait till tomorrow I'll find all of the good deals and links for you, but for now it's bedtime.
